Multifunction DAQ
Showing results forĀ
Search instead forĀ
Did you mean:Ā
How is Compact DAQ Clocked
I am considering using compact DAQ for my measurement application. I need simultaneous sampling on all channels and I need some analogue outputs to be clocked at the same time as the inputs. I notice that many of the c-series modules are simultaneously sampled but will this functionality be preserved across multiple input modules and will it be extended  to the analogue output modules that would use in the chassis?
(3,160 Views)
I have the same problem.
" äø€å¤©åˆ°ę™šęøøę³³ēš„é±¼"
labview@263.net
ęˆ‘ēš„äøŖäŗŗē½‘ē«™ļ¼šLabVIEWā€”ā€”åŒ—ę–¹å®¢ę ˆ http://www.labview365.com
ę¬¢čæŽåŠ å…„ć€ŠLabVIEWē¼–ēØ‹ę€ęƒ³ć€‹ē»„ā€”ā€”http://decibel.ni.com/content/groups/thinking-in-labview
(3,130 Views)
Hi Ralph,
NI Compact DAQ uses the STC2 chip to provide timing signals to all the modules over the back plane. Because of this every module will use the same sample clock, so if you have simultaneously sampling modules then these will all be syncronised. Correspondingly you can use the same sample clock to driver the analog output. How ever your scan rate will be determined by the slowest modules in you scan list.
Jon Bowers
Applications Engineer
NIUK
(3,109 Views)
