Multifunction DAQ
How does the ReadMultiSample method work
I am fairly new at this and have tried to find this information. I hav the following scenario:
I have an I/O-board that takes an analog signal and outputs another scaled signal. I want to measure the input signal for instance 5 volts and then the output signal 2.5 volts. I want to do this with say 1000 samples but I want it to read 1 sample from the input and then one sample at the output 1000 times. Little pseudo code would look something like this:
do 1000 times
valuein[i] = Read channel ai0 one time
valueout[i] = Read channel ai2 one time
I have created the, Task, VoltageChannels and named them, created an AnalogMultiChannelReader and.
My question is then: Can I use double[,] values = theReader.ReadMultiSample(1000) to achieve what I want to do.
Are there any other settings I have to make on my ChannelReader or Task to make it work as I want?
I appologize for this newbie-question.
Regards
Kjell
I hav a NI USB-6289 M-Series with Windows XP.
(3,444 Views)
Hey,
I'm not sure if I completely udnerstood what you want, there where so many "ins" and "outs" mixed together.
But if you want to get a measurement which does something like:
AI0 0
AI1 0
AI0 1
AI1 1
AI0 2
AI0 999
AI1 999
then this is exaclty what your card does when your acquire 1000 samples at AI0,AI1.
For more information please see here: https://www.ni.com/en/support/documentation/supplemental/18/sampling-terminology-for-ni-daqmx-and-tr...
Christian
(3,372 Views)
