Multifunction DAQ
BLUETOOTH EASY MODULE DETECT THE SIGNAL...
Hi every body.....i am an ele & comm engineer, my question is i have a bluetooth module full duplex and i want to detect the signal using labview,after i can detect the signal i will work on some applications maybe ECG monitor......................
i will place the link hope any person have any idea can help me i will be fully thank for him....... by the way the module can be connected using SERIAL PORT....
any idea or tutorial can help plzzz????
http://www.parallax.com/Store/Accessories/Communication/tabid/161/List/1/ProductID/550/Default.aspx?...
(3,433 Views)
There's a guy who make an example using serial to bluetooth with compact fieldpoint, but you can modify this example to use with PC.
Please refer to http://zone.ni.com/devzone/cda/epd/p/id/5488
(3,401 Views)
THANX 4 UR HELP.....but this is not the same as i want, i can explain more in details
i have the BT module which should be connected using RS232 serial port to the PC and i have to receive the original signal form other outside circuit like the ECG and send it to the BT module using (BLUETOOTH)
ECG-----AMPLIFIER-----TRANSMIT THE SIGNAL USING SENSOR----BT MODULE DETECT THE SIGNAL-----RS232-----LABVIEW
any idea ???
thanx
(3,390 Views)
In LabVIEW, search the Find Examples for serial. Look for Basic Serial read and Write.
-AK2DM
Message Edited by AnalogKid2DigitalMan on 10-22-2009 10:06 AM
(3,387 Views)
