Multifunction DAQ
How do you do continuous analog output that is timely?
Here are the screen shots requested. This shows the property node that I am calling:
I write new data to the buffers about every 7 seconds and check the propoerty each time. Here's the front panel:
This value is sometimes smaller on the first loop, but it always ends up showing the number of samples that I am writing.
Mike...
PS: Thanks for the example!
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 15
(2,561 Views)
Just tried the event example and it is perfect, thanks.
Mike...
LabVIEW Champion
Message 12 of 15
(2,558 Views)
Ok, a new problem. I am running the change detection event example and it runs fine -- for 999 times. Then it stops. To continue, I have to stop and restart the example.
Why 999?
Mike...
LabVIEW Champion
Message 13 of 15
(2,530 Views)
The defaults for the DAQmx Timing VI are
sample mode:  Finite Samples
samples per channel: 1000
I'm assuming you just need to set the sample mode to Continuous Samples.
Best Regards,
John Passiak
Message 14 of 15
(2,523 Views)
Did you configure your change detection task to be continuous?  I believe DAQmx defaults to finite acquisition of 1000 samples.
Dan
Message 15 of 15
(2,522 Views)
