‎05-07-2012 08:48 AM
How do you define (Link) a Physical Channel to a NI USB-6009 device on a Macintosh MacBook Pro MAC OSX?
I have downloaded and installed the latest driver software NI DAQmx Base 3.5
‎05-08-2012 03:58 PM
Hi rob546109,
Please see the following info which is from the readme file for DAQmx base 3.5:
DEVICE CONFIGURATION
Any time a new device is added or removed, you should run the following:
/Applications/National Instruments/NI-DAQmx Base/lsdaq.app
Make note of the device name (Dev1 for example) as this is the name you need to specify when creating channels in your program. A device name may change each time a device is added or removed.
Hope that helps.
‎01-18-2013 02:56 AM
my customer meets the same problem. He can see his device by lsdaq.app, but he can not define the Physical Channel in LabVIEW.
His devices: 6009 and 6501
LabVIEW 2012
NI-DAQmx Base 3.6.0
