Multifunction DAQ
How do I print my DAQ configuration file?
I would like to print out my DAQ configuration details, but MAX doesn't support printing, any ideas? Ideally, it also might be nice to export to Excel or Access. (Configured using MAX 2.2)
(2,454 Views)
Hello;
The current version of MAX doesn't have this option. Also, the .daq file is not compatible with Excel/Word formats. You can use the attache Labview VI to convert the basic properties of the virtual channels you have to a txt format, and then, export the modified file to Word.
Hope this helps.
Filipe
(2,454 Views)
