Multifunction DAQ
How do I output an analog signal from a file
I need to be able to output a chirp (some short signal) to an amplifier and right after record on 8 analog channels. Recording the channels seems to be no problem, but I can't seem to find a way to create my own signal and output it via IOtech's DaqBoard3000. Is anyone familiar with outputing a created signal with this board? If so, is there an easy VI or what can I do?
I've done a lot of reading and tried to do a lot of searching, but just don't seem to be getting anywhere with this board.
(3,017 Views)
I don't know if you noticed, but this is an NI board for NI DAQ products. If you are having problems with an IOTech product, it would be best if you contacted them. If you have a problem with reading a file, then please provide some details. Can you post the actual file you are trying to read? What data type do you need the output to be in (i.e. 1D array of DBL, waveform data type, etc.)?
(3,016 Views)
I wasn't sure if this was NI boards only.  Is there a forum for labVIEW support for non-ni boards? IOtech doesn't seem to have such a resource.
My problem is figuring out how to output your own, manually built signal. If I can get that far I'm sure I can figure out how make a working data structure. The only data output VIs I can find are those to create program defined waves (sines, saw, etc) in either a counted or continous format. I've really only been working with the included examples. Attached is one of the examples. I'm not sure if the subVIs are included.
(3,013 Views)
You could try posting to the LabVIEW board.
What you need to find is a lower level function in the IOTech driver. Something that does a direct write and not just predefined waveforms. If the VI that generates the predefined functions is not locked or password protected, look to see what is being called.
(3,007 Views)
