Multifunction DAQ
Wanted to buy PC-OPDIO-16
If this is not in the correct forum I would appreciate it if someone might point me in the right direction.
I would like to purchase 1 or 2 PC-OPDIO-16 cards.
Tom
(2,549 Views)
Hey Tom,
First off its not that this is the wrong forum I just think you might get a better response and quicker response if you were to call in becasue unfortunately that device is no longer being sold by National Instruments.  It is one of our legacy devices.  We do however have newer products that will perform the same function as the PC - OpDIO-16.   The main considerations that you should think of are the following:
1. Do you need to use this device with Traditional NI-DAQ drivers? (maybe because you have a lot of pre-written code that you do not want to rewrite)
2. How many channels do you need?
3. Do you need Ch-Ch isolation like the PC-opdio-16?
4. Do you need any correlated DI/O channels on your board. --Doubtful as the PC-opDIO-16 does not have any?
5.  What logic level are you looking for ?  5V TTL or 24V logic
6. What form factor do you want to use?  PCI, PXI, USB? etc...
Either repost here or please give us a call and we can find you the best solution.
Thank you
Charley Dahan
Global Account Manager
(2,532 Views)
