Multifunction DAQ
How can I read out my aquired samples
I am using MS Visual C++ to programme my application. First I tested my devices (NI PCI 6250, NI SC-2345, SCC-SG24) in MAX. Everything is working well. I have created a task and I can receive samples from my device using the test panel.
I want to use the anolog input from channel 0 for example to measure strain. That's why I used the example VC_ContStrainSamples.c to get started.
First I modified the programme using the functions DAQmxErrChk (DAQmxLoadTask("",&taskHandle)) to get my task from MAX working. The problem now is, that I don't know where to read out the samples. I thought there must be an array or something else but I can't find one. Is that correct?
When I use the function DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"?????",10.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000)); I get an error message that says unknown source terminal. What is a source terminal? I am using a German version of Max. Can someone give me an example what to use instead of ?????
Thanks BJ
(2,891 Views)
1. You have to use a function to get the values (DAQmxReadAnalogF64) for example. This Function has a parameter readArray[] where the acquired data is stored.
2. DAQmxCfgSampClkTiming(taskHandle,"?????",10.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000) The second paarameter defines the source of the sampleclock, you can specify a external clock source (for example "PFI0") or the internal clock ("Onboard Clock").
All functions are described in detail in the help file by the way (Start-Menue-->programme-->national Instruments-->ni-daq-->ni-daqmx c reference help).
(2,875 Views)
