Multifunction DAQ
Can I READ a digital OUTPUT port?
Is it possible to "READ" the output states of a digital port?
I have a 6229 board and using nidaqmx and programming in c.
Sally
(2,650 Views)
Sally,
That shouldn't be a problem. Just put a DAQmxRead right after your write command. Basically even though the line is configured as output, you can still make reads on the task. I have done this a number of times in LabVIEW, and doing it in C shouldn't be any different. Hope that helps, let us know if you have any other quetions concerning this.
-GDE
(2,637 Views)
