Multifunction DAQ
How I can delete a file ?
How I can delete a file (say, D:/AA/output.dat), which contains numeric data only, using labview vi ?
(2,869 Views)
Why did you post to the DAQ board?
In any case, the obvious answer is to use the Delete function on the File I/O>Advanced palette. There is a search button on the functions palette and the Help has a search option. Did you try either of them?
(2,868 Views)
