Multifunction DAQ
Averaging the rows in a multidimensional array
I have a file (file1.dat) that is created using the 'write to spreadsheet file vi', which writes the output of an photo-detector. The experiment has N trials. Each trial gives a 1D array of M number of data as a column. Once the experiment is complete, the file will contain N columns and M rows. How I can find the average of each row in labview ? The output (file 2.dat) should be a column of M elements, each element being the average of the N data contained in a row. Processing in excel or origin is not practicable. Usually, M>10000 and N>100. Can some one help ? For example:
file 1.dat:
A1   B1  C1
A2   B2  C2
A3   B3  C3
A4   B4  C4
File 2.dat should be:
(A1+B1+C1)/3
(A2+B2+C2)/3
(A3+B3+C3)/3
(A4+B4+C4)/3
Thanks !
(3,304 Views)
Accepted by topic author kumban
If all you've got in the file is data with no headers or footers, it should be pretty simple.  Look at this:
-Kevin P
(3,296 Views)
it works well ! Thank you Kevin
(3,266 Views)
