‎04-03-2007 08:20 AM
‎04-04-2007 02:09 PM
Hello Asha,
Indeed, that card is supported under
DAQmx 8.3 and it should work without any problems, especially the ones you are facing. I have tested this
same setup with no problems.
At this point I would recommend the
following:
Other options we have is to install
DAQmx 8.5.
To have more input about this problem
can you post back your OS and if you have any other hardware.
More information will give us more
insight of where the problem could be,
‎04-05-2007 01:28 AM
Thanks Gerardo for your help.
I had already tried what you have suggested. steps 1,2, 3
Remove the hardware, Install DAQmx 8.3. Turn off computer adn add add hardware
But still i see the same blue screen with the same message
Regarding the system configuration, there is no other hardware installed and OS version is Windows 2000 SP4, 1,039,804 KB RAM
‎04-05-2007 05:16 PM
