Multifunction DAQ
Groundig loop with a LM35
I have to acquire an indoor temperature by using a LM35.
The issue is that this LM35 voltage catch much noise.
The distance from LM35 and DAQ system (6008) is about 5cm.
I used a separate (floating) DC generator to power LM35
and, of course, a differential input, so to avoid common
ground reference with no success.
If I use a RSE input (same GND for LM35 and AI) is a disaster:
300mV of noise!
Any suggestion? How I can minimize this issue?
Thanks in advance
(3,210 Views)
Try the following:
  • Short the 2 pins for an AI channel and take a measurement. Do you read 0 flat?
  • connect a low voltage battery to the AI channel pins (say 1.5 V). What do you read?
This is to test if your 6008 is working
AlessioD
(3,192 Views)
