03-24-2011 11:57 AM
I am using several PXI DAQ devices that, upon install of all the drivers and associated NI software, are recognized as DAQmx in the Measurement & Automation Explorer. However, the application that I wish to use these devices in requires that they be recognized as traditional (legacy) DAQ devices (not DAQmx) for the existing code to work properly. I have installed the traditional DAQ drivers (version 7.50 - beta) alongside the DAQmx drivers but have not yet been able to get my devices to be recognized as legacy.
How can I force the devices to be recognized as traditional (legacy) DAQ instead of DAQmx?
I do not need to use DAQmx for my application. Can I selectively uninstall DAQmx and keep the traditional DAQ drivers.
I am confident that the combination of hardware, drivers, and my OS will work together correctly since, at one point, I did have it set up properly.
03-24-2011 12:06 PM
What operating system are you using? The Traditional NI-DAQ 7.5 beta should only be used on Windows Vista. There is a known issue with the Traditional NI-DAQ 7.5 beta on any OS that will result in being unable to use devices with Traditional NI-DAQ if NI-DAQmx is installed. There are no plans to release an updated beta version and no known workaround. We strongly encourage anyone using the Traditional NI-DAQ beta driver to develop and test NI-DAQmx code on a separate machine and to replace the Traditional NI-DAQ code as soon as possible.
03-24-2011 02:08 PM
I am using Windows 7 (32 bit). Although it is not officially supported, through great effort, I was able to get it working once before. But I have been unable to recreate that success. I think it might have required careful installation so as not to install the mx drivers and only installation the traditional drivers.
Are you saying that if I was using Windows Vista, it would automatically recognize these devices as traditional instead of mx?
03-24-2011 02:11 PM
The issue exists for both Vista and Seven. Some machines may be able to use both side-by-side, others won't. We haven't really seen a pattern as to which machines are affected. The best policy when using the Beta driver is to not install NI-DAQmx along side the beta Traditional NI-DAQ driver, regardless of OS.
03-24-2011 10:27 PM
I was able to selectively uninstall just the DAQmx drivers, and then install only the traditional drivers. In doing so, my DAQ devices were properly recognized. However, there was still a mysterious problem of one of the cards not functioning correctly unless I swapped it with another card in a different slot. Then Windows saw it and installed it (so say the notification balloon the popped up), and then everything worked fine.
