12-15-2006 07:59 AM
12-15-2006 08:31 AM
12-17-2006 08:30 AM
12-17-2006 11:21 PM
12-18-2006 08:43 AM
12-18-2006 09:03 AM
12-20-2006 08:18 PM - edited 12-20-2006 08:18 PM
Message Edited by sspine on 12-20-2006 08:21 PM
12-21-2006 08:38 AM
Hey Pine,
The 8186 will be slower than the 8196, but I'm guessing that you would only get a 10-20% reduction in performance, not a 70% reduction... Also, the A/Ds and D/As are slower on the 6052E, but still at well above the loop rates we are shooting for... I have never personally tried diabling the USB port through the ini file (I'm a little old school) - what I would like for you to do is to verify that the USB has been disabled through the BIOS. Doing this is pretty simple, connect a monitor and keyboard to the PXI controller and go into the setup settings. You should find the USB port under the settings for the "integrated peripherals"... Let me know if you can confirm the USB settings in the BIOS, in the meantime, I'll double check to make sure I'm not missing anything...
Cheers, Zen
12-21-2006 02:09 PM
T2a 46.6 kHz
T2b 20.2 kHz
As you can see the Pentium 4 architecture has had a significant impact on the speed of our tests (a decrease of performance around 40 MHz) - I don't believe that the 6052E had as much of an impact. Ensure that you did not enable debugging on the VIs I sent you and ensure that the ethernet mode is set to polling through MAX and you should be able to get numbers close to the ones shown above. Please let me know what you get. Thanks, Zen
12-21-2006 10:44 PM
