FIRST Robotics 2010 LabVIEW Installation?
When I try to install LabVIEW 8.6.1 using the FIRST Competition Software Kit, I can enter my directory, organization, name, etc. and it will start installing:
However, when it says initializing LabVIEW Installer (1 out of 15 Products):
the LabVIEW installer will start, complete the progress bar and disappear. Soon after, the 8.6 Real-Time Module starts its installer and leaves me with a message:
"NI LabVIEW 8.6.1 must be installed before you can install the NI LabVIEW 8.6.1 Real-Time Module. "
By the way my system specifications if you need them are:
PC Model: Inspiron 1520
OS: Windows Vista Home Premium 32-bit
Processor: Intel Core 2 Duo T7100 @ 1.80 GHz 1.80 GHz
Memory (RAM) : 2.00 GB
Hard Drive: 150 GB
(4,038 Views)
Accepted by mat3049
Hi mat3049,
Could you please post this to the FIRST Discussion forums located at ni.com/first?  Those forums are actively monitored by people involved in FIRST.  They will be best able to help you with this installation issue.
Message Edited by Burban on 01-25-2010 12:19 PM
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(4,014 Views)
Oh I'm very sorry, the link I clicked said it redirected to FIRST forums, but thank you very much for your tip!
I actually found the problem and solved it. 😄
It seems like NI MAX was glitching up somehow and managed to fix the installation.
Again, thank you very much!
(3,994 Views)
