External reference for analog output on USB-6259
According to the manual the 6259 device can use an external reference for analog output.
My problem is that I can't find the setting to select it. The NI-DAQmx help says: "The external reference voltage settings are available as a Channel property in the Analog Output»General Properties»DAC»Reference Voltage".
But where do I find this setting? I'm unable to find it in both MAX and SignalExpress. Do I need to use LabView to access this property?
Or is the external reference feature not available on USB-devices?
Joacim
(4,685 Views)
I've found that it can't be done in MAX, but it's possible in LabView.
However I can't get the "External", for the reference source, to work properly. Any suggestions?
(4,656 Views)
deleted
(4,654 Views)
Hi Joacim,
In the example, External Source is named Dev1/EXTREF. EXTREF do not exist on USB-6259. You need to use one of the two APFI channels.
E.g. Dev1/APFI0
If you already do that, any error messages? Or how does it not work?
Klas
(4,635 Views)
Found the problem.
I connected the external reference voltage to PFI0. After I switched to APFI0 it worked.
I also found a better example vi here.
Thanks for your reply.
(4,614 Views)
