07-23-2007 06:21 PM
07-24-2007 07:21 PM
If you were looking for a new solution to replace the 6024 I would point to our new USB M series bus powered devices. http://sine.ni.com/nips/cds/view/p/lang/en/nid/203092 They provide better counter circutry than the PCMCIA 6024, and they still maintain the same high Analog input performance. The USB bus provides a great way to have a ready to go DAQ solution for your laptop. Please let me know if there is any other info I can give you regarding this issue. |
07-24-2007 10:25 PM
11-20-2007 04:13 PM
02-22-2008 08:54 PM
I have a similar configuration as 'USFphy', but my DaqCard is a 6062E and the system crashes when I install any Nidaq 7.x driver on the Inspiron 1720 running with XP. A Vista install on a second hard drive on the same machine using Nidaq 8.6.1 works just fine. Is there a way to change the IRQ for this card? Is the IRQ for this card fixed, so it runs into IRQ conflicts with XP? The software we have written requires XP and Nidaq 7.x for now and we try to avoid recompiling with a different Nidaq version than 7.x. Any ideas?
Any help is highly appreciated.
02-25-2008 06:55 PM
Hi Kmone,
Welcome to the forums. With regards to changing the IRQ for specific cards, you can follow the procedure in the appropriste Knowledge Base Document: Disabling Interrupt Request (IRQ) settings for National Instruments Hardware in Windows or DAQPad-1200 Device Not Responding to First IRQ Level Using Windows. Or you could possibly see your operating system's user manual for information on assigning specific IRQ levels to a hardware device.
I have some further questions for you though:
1) What specific version of DAQ are you using, 7.what?
2) Was you program developed on another computer with the DAQ driver and you are trying to install the software on this Inspiron so you can move it there and run it?
3) Could you describe what occurs when you say that your system crashes upon the installation of the DAQ driver?
4) Have you tried chaging the IRQ in Windows Device Manager as pointed to in the above Knowledge Base Documents?
5) Have you disabled the ACPI extraction layer? This might cause issues since it automatically manages the IRQ numbers.
Hope this information helps, Mallori M.
05-22-2008 09:17 AM
05-22-2008 10:52 AM
05-13-2009 04:31 AM
I would like to add some results that may be useful. We have made the DAQCard-6024E work with an ExpressCard Slot. Here are the details:
1. We used a new Dell Vostro 1510 Laptop with 54mm ExpressCard slot, running Windows XP.
1a. Our customer also used a Dell XPS1730 laptop, running Windows XP.
2. We used the Duel Adapter installed according to their instructions
3. We used NI-DAQmx 8.8 and LabVIEW 8.6.1
4. We plugged in a DAQCard-6024E into the Duel Adapter.
5. All worked fine.
Notes:
1. It also works with Traditional NI-DAQ 7.4.4
2. It does not work with NI-DAQ 6.9.3 because the card does not respond to the first IRQ level. This is a known issue with NI-DAQ 6.9.3 and new laptops. This means that the DAQCard-700 is not supported.
3. We have not tried it with Windows Vista or a 34mm ExpressCard slot.
4. On Windows XP it works with Duel Adaptor driver version 1.0.0 or 1.0.1
