Multifunction DAQ
Event Structure
Hi Dev:
Thanks! I trust you. I was feeling that way a while ago with optimistic and courage. I will keep it in my mind.
But I think I doubt is after I research something, I work on my project, at that time I am not very sure something, could I ask you?
Message 61 of 63
(948 Views)
Hi Dev:
I don't know if I really don't know something and need your guildance. Could I ask you? Like the here.
As you know, my program need to put a red or green light at the end to show pass and fail of the test to the operator. After that, I have to save this record in the excel file, do you think event structure that you gave me will work? Previous attached is my file that I use to save file. Do you think that will work. You see "Write LabVIEW measurement File" in enable event case.
Eveyone need guildance and as the matter of fact. I am very lucky to know you. Could you please give me a chance? I think I know you. I am very lucky and happy anyway.
Message 62 of 63
(943 Views)
Hi
 Have a look at any data logging example Vi's they explain you how to do it.
go to examples and search for File read write examples, data logger examples.
This should help you.
For making test pass, test your test parameter value against some set value, as in attached VI
regards
Message 63 of 63
(922 Views)
