Multifunction DAQ
Error code -50152
I am not sure if this is the right forum, but I am using a PCIe-7367 with NIDAQmx on a Ubutu 24.04 system. I am getting the following error message when trying to read the buffer:
A hardware failure has ocurred. The operation could not be completed as specified. Error code -50152
Since I couldn't find this error code in the online documentation, does anyone know what might be the cause?
Many thanks!
(1,251 Views)
NI does not have hardware with model number of 7367. What is the correct model number?
What is the NI-DAQmx version installed? The first supported version for Ubuntu 24.04 is NI-DAQmx 2024 Q4.
https://tmesystems.net/
(1,238 Views)
Sorry for the typo. The model number is PCIe-6376. The NI-DAQmx version installed is indeed NIDAQmx 2024 Q4.
(1,212 Views)
DAQmx Error -50152: A Hardware Failure Has Occurred
The KB was written for Windows. You might need to do some google to find out what's the equivalent for Linux.
(1,190 Views)
(916 Views)
