Multifunction DAQ
Error: DAQ-STC Counter functions missing from library
Using LabView 6.1, NI-DAQ 6.6.1 for MacOS on a laptop.
DAQ Hardware: DAQCard 16E-4.
When trying to use the advanced counter functions (for DAQ-STC type counters), LabVIEW generates an error saying that it can't find the function in the library. The code interface nodes for the VIs don't seem to be attached to anything. I've installed the latest version of DAQ Drivers for Mac; am I missing something here? Any insight into this problem would be appreciated.
jdk
(2,507 Views)
Hi jdk,
I think it could be just an installation issue. I assume that you are using Mac 9.1. I've run LV 6.1 with NIDAQ 6.6.1 on Mac 9.1 and it works just fine, including DAQ-STC counter functions.
If LabVIEW 6.1 was installed without DAQ support, run the LabVIEW 6.1 installer and perform a custom installation for DAQ support. Then, run
the NI-DAQ 6.6.1 installer to upgrade NI-DAQ.
Hope this helps.
Pravin Borade
Applications Engineer, National Instruments
(2,507 Views)
