11-01-2005 10:53 AM
I am getting the following error code when using the NI USB 6009
I am using it in continous acquition mode. I am stoping the acquisitinon when a certain limit is met on the analog input, sending a digital output, and then starting the acquisition again.
This only happens after many hours of operation. It also seems to be a function of sample rate i.e. the higer the sample rate the more frequent I get this error.
Error - 50550 occurred at DAQmx Stop Task.vi
Possible reason(s):
A synchronization object was not acquired within the time limit.
The operation could not be completed as specified.
Task Name _unnamedTask <6246>
Please advise
11-02-2005 07:13 PM - edited 11-02-2005 07:13 PM
Message Edited by Ryan V on 11-02-2005 07:13 PM
11-02-2005 08:00 PM
I am having the same problem as this guy
How do I create a Notify Procedure using NIDAQmx and USB-6009?
I think once this problem is solved my problem will be solved too.
I am just performing continous data acquisition. I am doing something I don't normally do. I am creating and clearing tasks frequently. I am wonding if this might be causing the problem. This error only occurs after reltivly long periods of time i.e 2 hours
Can you give me a little more insite as to what this error means?
I am unable to post code at this time.
11-03-2005 01:01 PM
05-22-2006 01:05 PM
05-22-2006 04:24 PM
