Multifunction DAQ
Error, 8 lines in channel, 1 line in data
I've set up a DAQmx read for a DI (boolean right?)  Well somehow it gets 8 lines in the channel.  Any suggestions will be helpful.
(2,911 Views)
Accepted by All DAQed out
Hi There,
Thanks for the post and I hope your well today.
Are you using LabVIEW? If so, if you go to Help>>Find Examples.. NI example finder>>Hardware Input/Output>>DAQmx>>DI, could you maybe test this using the Read Dig Chan.vi and the Read Dig Port.vi?
To read multiple lines you can use Dev1/port0/line0:7
Also on the polymorphic vi remember to select  single channel >> signal line >> Booean.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,895 Views)
