Error-201003 occured at DAQ Assistant
Hello. I'm using "cDAQ-9178" and "NI 9215" and "NI 9402" are added on.
However, when I run a Labview code, "Error-201003" occurs.
Device cannot be accessed. Possible causes:
Device is no longer present in the system  /  Device is not powered  /
Device is powered, but was temporarily without power  /  Device is damaged
(Error is shown like the 1st and the 2nd figures below.)
(Sheme of the logic is in the figure below.)
Thank you.
(10,491 Views)
Hi keuntae,
did you try resetting the device or running a self test?
(10,477 Views)
Yes. I'm afraid that I already did that.
(10,469 Views)
And what happens? Do you get the same error?
(10,465 Views)
Accepted by GuGuGooo
I could be something with the driver
check this:
Error 201003 at Test Panel in MAX or While Running DAQ Assistant
http://digital.ni.com/public.nsf/allkb/5413F392D88326148625746B006745C5
In this forum, they talk about the same error:
Spontaneous Error Code 201003 for PCI DAQ Setup
http://forums.ni.com/t5/SignalExpress/Spontaneous-Error-Code-201003-for-PCI-DAQ-Setup/td-p/830707
(10,443 Views)
make sure DAQmx version you got is compatible with the Labview you are using, check the readme file of that version of the driver
(10,441 Views)
