‎01-09-2006 06:31 PM
‎01-10-2006 01:10 AM
‎01-10-2006 01:18 PM
Sorry about the missing information, I'm a bit new to all of this.
The board has worked in the past, quite successfully to run the application I am using in for, in both the current computer and another one.
I am currently installing a newer version of the NI DAQ software, so it will be interesting to see if it fixes the problem.
I also tryed to test the board under the traditional DAQ panels in MAX with the same result, of an error 200329 in the analog input.
As far as I know the timing that I am using is based on the internal clock of the computer and i'm asking it to perform a set number of measurements each time the stepper motor moves the a number of steps. This program application has worked fine in the past, it is just the last few days that has seen it giving me this error message. So i'm pretty sure its not my program I wrote.
Ange
‎01-10-2006 01:34 PM
HI,
I have just finished installing the newer version of NI-DAQ onto my computer and my system is now running properly. Obviously just a bit behind in the updates and it crashed.
Hopefully it will continue to work and I won't have any further problems.
Thanks for your help
Angela
‎01-10-2006 04:36 PM
well it worked fine for an hour or so, behaving itself and collecting data as it should (apart from a small programming error on my part in labview) and then it just stopped and gave me the same error message as before!!
The error message is in the first post on this thread and the current message is exactly the same as are all the parameters under which it should be operating!
Thanks in advance for your help
angela
‎01-10-2006 04:51 PM
Hi again,
Just ran the DAQ Diagnostic Utility as was suggested in another thread and got the following results
11/01/2006 11:49:01 a.m.
Results saved to: C:\NIDAQ8\diagnostic\Diagnostic Results 2.txt
Selected Device: Dev1
Device Type: PCI-6034E
Serial Number: 10AE771
Device Support: (PASS)
NI-DAQmx Version: 8.0 (PASS)
Device Reset: (PASS)
The device was last self-calibrated on: 11/01/2006 8:23:47 a.m.
Running Calibration ... FAILED for the following reason:
Error -200329 occurred at DAQmx Self Calibrate.vi
Possible reason(s):
An error has occurred while attempting to configure the device for an analog input acquisition.
If an external master timebase is being used, make sure the source is connected and generating an appropriate clock. Otherwise, contact National Instruments Technical Support.
-------------------- Testing Counters... --------------------
Testing CTR Buffered Pulse Generation... (PASS)
Testing CTR Single Pulse Generation... (PASS)
-------------------- Testing Analog Input... --------------------
Testing AI Ground Reference... (FAIL)
************ Test FAILED for the following reason ************
Error -200329 occurred at DAQmx Start Task.vi
Possible reason(s):
Testing AI Voltage Reference... (FAIL)
Possible reason(s):
Testing AI Finite Sample Clock... (FAIL)
Error -200329 occurred at DAQmx Control Task.vi
Possible reason(s):
Testing AI Finite Sample Clock Frequency... (FAIL)
Possible reason(s):
-------------------- Testing Digital IO... --------------------
Testing DIO Lines... (FAIL)
Incorrect digital value read internally from Dev1/port0/line1. Expected a tristate value of TRUE, Read FALSE.
Testing DIO Ports... (FAIL)
Incorrect digital value read internally from Dev1/port0. Expected 1, Read 5.
----- DIAGNOSTIC TEST COMPLETE -----
Any help will be much appreaciated
Thankyou
angela
‎01-11-2006 11:08 AM
