Multifunction DAQ
Encoder sampling at old clock speed
I’m having some trouble collecting points from the encoder on a USB 6221 board on Windows 7 x64 using NI-DAQmx 9.3.0. Here is a little bit of the background on what we’re doing. Our application creates a single encoder task and keeps it alive for the duration of the application. We do this in order to preserve the counter value because stopping and creating a new tasks causes the encoder counter to be reset back to zero. Whenever the application is sitting idle, we sample the encoder at 200 Hz in order to present a “live” display. Whenever we are ready to sample the encoder to collect a waveform, we do a little magic to clear out any potential stale values in the buffer and provide a new clock at the desired sampling speed.
This all worked well on Win XP using NI-DAQmx 8.9.0, but now on Win 7 the first few points we collect when calling DAQmxReadCounterU32 appear to be sampled at the old clock speed. It’s very random in nature, which leads me to believe it’s a timing issue.
Since nothing has changed on our end except the OS and the NI API version, I’m not entirely sure how to tackle this problem.
Any suggestions?
(3,991 Views)
David,
How are you switching clocks? It's possible that the new software runs a little faster which has exposed a race condition in your code. You can try putting a Wait(ms) VI before starting to collect your waveform data, but after switching the clocks. Would it be possible to try this?
aprillest
(3,948 Views)
