Edit Max programattically
I would like to be able to set up a channel in max, then programmatically change the scale on that channel. I would like to do this so that I can call that channel in a seperate VI without having to run through the create channel and scale vi's. So far, this does not look possible? When I edit a scale it does not change the values in MAX?
(3,175 Views)
Accepted by deskpilot
Hi deskpilot,
This is achievable using the DAQmx Save Scale vi, which can be found in the following pallette:
Meaurement I/O >> DAQmx >> Advanced >> System Setup >> Storage
For an example of how to do this, I would take a look at the following Developer Zone example:
Change DAQmx scales in LabVIEW and Save the Changed Scales to MAX
John Passiak
(3,155 Views)
