Multifunction DAQ
Drivers
Are the required myDAQ drivers seriously 1.6 GB?
What is this?
(3,847 Views)
MGD,
myDAQ uses functionality common to the DAQmx and ELVISmx driver packages, so rather than building a special myDAQ driver package we've decided to use existing packages which already contain the required drivers. We do this for most of our DAQ products to simplify setup. I understand your concern though, 1.6 Gb is a lot of storage space. On the bright side, DAQmx and ELVISmx are the only packages you would need for a good chunk of our hardware, so you would only have to install them once to use a lot of our products.
Austin
Staff Software Engineer
NI
(3,803 Views)
