Does DAQmx work with PIXe hardware?
Hi I am hoping to write a program in C# to interact with my PIXe chassis and associated cards. I don't want to use Labview or Labwindows. Is it possible to access this hardware through DAQmx. I can't tell from the documentation which NI products are compatible with DAQmx. Also does the NI license allow you to use DAQmx if you haven't bought Labview or Labwindows? Right now I have the trail of Labwindows installed so it's hard to tell if once the trail is over will DAQmx keep working.
Connor
(421 Views)
DAQmx is the driver that supports all NI DAQ hardware (except a bunch of legacy one which require DAQ driver and not the mx version). Look up your hardware user guide to see if it works with DAQmx or a different driver.
Yes, you can use DAQmx without LabVIEW or LabWindows as it is for the control of respective NI Hardware.
List your PXIe cards, I can help map them to respective driver you need.
Santhosh
Soliton Technologies
(400 Views)
