04-30-2007 08:50 AM
05-01-2007 01:06 PM
05-07-2007 10:57 AM
05-08-2007 10:07 AM
05-17-2007 09:01 AM
Jesse,
I have attached an example that shows the behavior. Each time it runs you may or may not get the same results. It uses named channels set up in Max. "10kv Enable" is configured as a Write to Digital Line, "Read" to Read a Digital Line. It seems that using these "Easy DIO" vi's results in all of the digital lines being configured every time one of them runs. Is this usual behavior for this combination of vi's and the DAQPad 6020E? The manual says the channels can be configured individually, but it doesn't seem to work that way.
Butch
05-17-2007 09:03 AM
05-17-2007 12:20 PM
05-17-2007 01:38 PM
DIO Port Config configures only one named channel, so a single instance is not enough.
I did as you suggested, with the addition of a second DIO Port Config, and the digital input line is still pulled low when the output line is configured. It goes back high when the second DIO Port Config runs.
While observing DIO Port Read and Write during the execution I noticed that they both generated Warning 10612: The specified line does not support transfer in the specified direction.
Is this behavior peculiar to the DAQPad 6020E?
05-17-2007 03:48 PM
