Digital Input Edge Counting
I realize the NI DAQ 6001 has an input for edge counting however I need 3.  I tried editing a VI I found on this forum, however it won't let me connect the input up to the case structure.  It only works if I hook up the Boolean as an button etc... I read somewhere on the NI 6001 manual that these digital input channels cannot be used for edge counting? Any ideas on what to do?
(2,767 Views)
Accepted by LPKirby
(I don't recommend the way, sampling rate is based on loop timing on While Loop, and it's strongly affected Windows load.)
To resolve your issue, use "Index Array" function.
Certified LabVIEW Developer
GCentral
(2,697 Views)
