04-20-2009 10:08 AM
I want to read voltage from a potentiometer powered with the +5V and GND signals from the DAQ board. I have thought of connecting GND output directly to the potentiometer and using single ended mode. Is there any point in using differential mode in this case. If so, should I just connect GND output directly to the AI- input?
Thank you.
04-20-2009 12:32 PM
Single ended should work fine.
-AK2DM
04-21-2009 12:44 AM
04-21-2009 12:48 AM
04-21-2009 02:57 AM
It's more a question of cable lenght, ground loops, sensor impedance and noise coupling.
If your potentiometer is in a 1k-10k and less than 1m cable in a EMC calm lab, (or all inside a housing) you don't have to worry.
I would add a 100nF (or up to 1µF) from the slider to ground for denoising during slider movement, and add a digital filter..
