Multifunction DAQ
Differential,RSE mode & NRSE
Could you tell me when I should prefer to use differential , rse or nrse in a floating signal source? It is very hard to determine.
Is there a way to judge?
Also, is there any way to judge when I should prefer to use differential or NRSE in grounded signal source.
3) what is the valid bias resistor range for NRSE mode? Is it 10kohm<x<100kohm same as differential mode?
I am in a urgent. I appreicate if you can reply to me promply
Message 1 of 1
(3,526 Views)
