Multifunction DAQ
Different reading when using different software
I am using NI9205 and NI 9171USB DAQ, A battery and a DC output were wired to NI9205.
However when using MAX (creat task function), Signal express or a program I created using DAQmx functions to get the voltage output,
I got different readings for the same channel (20-50% variation). and it turned out that only the readings from my own program are the same as what I measured using a portable multimeter,
Really do not understand how could that be possible? what could be wrong with the MAX and Signal Express?
BTW, I have made sure that I set the connection method to be RSE in all three cases.
Anyone's input will be greatly appreciated.
(3,114 Views)
Accepted by topic author lksusier
Problem solved. Nothing is wrong with the DAQ platforms
(3,101 Views)
