Determine AC Current
Hi i am having trouble determining AC Current. I am using an op-amp and i am trying to read the voltage and convert the voltage back into current using LabView software. I cannot get any consistant results. I was wondering if someone knew a good op-amp configuration and then how to convert it back into amps.
(3,183 Views)
Accepted by VeritasAequitas
It appears that this issue has been posted on another thread, which may be found here. Any further questions/updates should be posted on that thread. Thanks!
Daniel S.
(3,147 Views)
