Multifunction DAQ
DaqMx trouble with Labview
Hi :
Installed Labview 2012 yesterday, daqmx was already installed (9.6) since I was using it with Measurement Studio 2012.
Labview seems not to recognize DAQmx.
I'M using Labview exemples  and getting daq mx errors.
thanks.
(3,273 Views)
Accepted by topic author ELBOB313
You have to install DAQmx after LabVIEW. Since LabVIEW did not exist when you did the DAQmx installation, the required LabVIEW folders would obviously not have been created.
(3,265 Views)
Just to add to Dennis's comment, all you need to do is reinstall your DAQmx.  All that it will see that it needs to do is add the LabVIEW support, so the install should be really quick.
(3,254 Views)
