Multifunction DAQ
DaqMx driver only for specific hardware
Is there any possibility to install a driver only for a particular NI hardware like PCI-6220? When I install NI DaqMx 9.7, it installs drivers for all the NI products which takes too much space on hard disk. I have constraints on hard disk size and also on RAM. Please advise.
(4,554 Views)
No. DAQmx is s single driver for multiple devices. You do have the option of deploying the core version of the driver from a development system. You also have the option of using DAQmx Base. It is a smaller driver but has fewer capabilities.
(4,551 Views)
While DAQmx doesn't support installing individual drivers, you can install subsets of DAQmx (depending on your needs):
http://zone.ni.com/reference/en-XX/help/370466V-01/daqhelp/subset/
core: http://www.ni.com/download/ni-daqmx-run-time-engine-9.7.5/4241/en/
~193MB, NI-DAQmx 9.7.5 Core Runtime contains all the features of the full version of NI-DAQmx 9.7.5 except for the following:
  • Application development environment (ADE) support for LabVIEW, LabWindows/CVI, and Measurement Studio
  • The DAQ Assistant
  • NI-DAQmx documentation
  • LabVIEW Real-Time support
  • Measurement & Automation Explorer (MAX)
config: http://www.ni.com/download/ni-daqmx-run-time-engine-9.7.5/4243/en/
~873MB, NI-DAQmx 9.7.5 Configuration Run-Time provides a smaller footprint run-time driver for deploying applications developed using NI-DAQmx 9.7.5 (Full Version).  NI-DAQmx 9.7.5 Configuration Run-Time contains all the features of the full version of NI-DAQmx 9.7.5 except for the following:
full: http://www.ni.com/download/ni-daqmx-9.7.5/4240/en/
~1.3GB
(4,527 Views)
