‎05-05-2014 06:33 AM
Is there any possibility to install a driver only for a particular NI hardware like PCI-6220? When I install NI DaqMx 9.7, it installs drivers for all the NI products which takes too much space on hard disk. I have constraints on hard disk size and also on RAM. Please advise.
‎05-05-2014 06:52 AM
‎05-05-2014 02:25 PM
While DAQmx doesn't support installing individual drivers, you can install subsets of DAQmx (depending on your needs):
http://zone.ni.com/reference/en-XX/help/370466V-01/daqhelp/subset/
core: http://www.ni.com/download/ni-daqmx-run-time-engine-9.7.5/4241/en/
~193MB, NI-DAQmx 9.7.5 Core Runtime contains all the features of the full version of NI-DAQmx 9.7.5 except for the following:
config: http://www.ni.com/download/ni-daqmx-run-time-engine-9.7.5/4243/en/
~873MB, NI-DAQmx 9.7.5 Configuration Run-Time provides a smaller footprint run-time driver for deploying applications developed using NI-DAQmx 9.7.5 (Full Version). NI-DAQmx 9.7.5 Configuration Run-Time contains all the features of the full version of NI-DAQmx 9.7.5 except for the following:
full: http://www.ni.com/download/ni-daqmx-9.7.5/4240/en/
~1.3GB
