Multifunction DAQ
DC to AC Voltage using PXI-6025E
I was wondering if there is a way to convert the DC output from a PXI-6025E to an AC output using software?  I need to achieve a 4.25VAC exication.
(3,692 Views)
What exactly do you mean? The analog out of the board will output a waveform if that's what you specify. If you're using LabVIEW and DAQmx, look at the shipping examples for Hardware Input and Output>DAQmx>Analog Generation>Voltage.
(3,686 Views)
Analog output's are current limited to ~10mA I think. You may need to buffer the output to supply enough current drive to you device that requires excitation, suggest you verify specs on both devices.
(3,679 Views)
I am fairly new to use AC so I may not really know what I am talking about, but I was under the impression that I only had a DC analog output.  I will check the examples that come with LabVIEW.
(3,669 Views)
Nate,
You are right, you do have DC analog outputs, but you can output a series of voltages in such a way that it resembles an AC source (sine wave).  I would follow the suggestion posted by Dennis to check out the existing LabVIEW examples, maybe one like "Cont Gen Voltage Wfm-Int Clk.vi".
-Alan A.
(3,649 Views)
Thanks for all of the information.  I got the signal to work, but do not have enough current to get it to work correctory justing just the 6025E output.  Oh well, it was worth a shot.
(3,635 Views)
Like I suggested before use a buffer (i.e. op amp or transistor circuit) to boost the current from the DAQ to drive your device.
(3,628 Views)
