What exactly do you mean? The analog out of the board will output a waveform if that's what you specify. If you're using LabVIEW and DAQmx, look at the shipping examples for Hardware Input and Output>DAQmx>Analog Generation>Voltage.
Analog output's are current limited to ~10mA I think. You may need to buffer the output to supply enough current drive to you device that requires excitation, suggest you verify specs on both devices.
~~~~~~~~~~~~~~~~~~~~~~~~~~ "It’s the questions that drive us.” ~~~~~~~~~~~~~~~~~~~~~~~~~~
I am fairly new to use AC so I may not really know what I am talking about, but I was under the impression that I only had a DC analog output. I will check the examples that come with LabVIEW.
You are right, you do have DC analog outputs, but you can output a series of voltages in such a way that it resembles an AC source (sine wave). I would follow the suggestion posted by Dennis to check out the existing LabVIEW examples, maybe one like "Cont Gen Voltage Wfm-Int Clk.vi".
Thanks for all of the information. I got the signal to work, but do not have enough current to get it to work correctory justing just the 6025E output. Oh well, it was worth a shot.
