Multifunction DAQ
DC offset with icp accelerometer
I am using a NI 4472 card to measure several different signals. Some of them need to be DC coupled and the ones with the accelerometers need to be AC coupled to avoid a DC offset. The problem is that I get a DC offset on the accelerometer outputs unless I configure all of the channels for AC coupling. I am using a vi that I downloaded from NI to configure the channels (attached).
(3,440 Views)
Please take a look at the following document:
http://digital.ni.com/public.nsf/websearch/AD9EC11DA7E9C41486256D02005C9BEA?OpenDocument
Basically you need to give the filter on the board a few seconds for the DC signal to decay down to 0V. Then you should not see the offset with the AC coupling.
Bryan Snarr
Field Engineer
Northern California
(3,440 Views)
