Multifunction DAQ
DAQmxCreateAIAccelChan
Can I used a array instead a single data in the function "DAQmxCreateAIAccelChan" the parameter called "Sensitivity",  the type required is float64.  We often use more than one channel and the sensitivity is not same.
(3,088 Views)
You may configure as shown in the pic
Note: Also Pass physical channnels in form of an array ( as shown for sensitivity)
(3,079 Views)
