Multifunction DAQ
DAQmx with Heidenhain IK220
Hi everyone!
I've a heidenhain ik220 counter card, connected to two heidenhain MT12 sensors. i installed the drivers provided by Heidenhain. My OS is W7x64. With example apps i can connect and get values from sensors without problems, but i tried using DAQmx assistent (integrated on VS2012, with NI Measurement Studio) without sucess. In assistent, when a choose the signals, in hardware listbox appears "ni-daq no supported devices found". Maybe NI software does not support IK220?
I have NI Device Drivers Aug13 installed too.
Waiting for feedback,
Rúben Jerónimo
(4,875 Views)
Hi there,
Thanks to post on NI forums.
Since the ki220 is not an NI board, DAQmx will not support it. Sounds logical. Now, if you are looking for some examples and starting point
for your application, you should first look at the manual provided by the vendor :
User's Manual
http://irtfweb.ifa.hawaii.edu/~tcs3/tcs3/vendor_info/Heidenhain/IK220/IK220_en.pdf
Here you'll find example, software API function etc.
Hope that help.
Regards
Victor F. | Systems Engineer
Certified LabVIEW Developer | Certified TestStand Architect
National Instruments Budapest
(4,833 Views)
hello. could you share the shell for ik-220? i will be very grateful to you. thank you
(466 Views)
