Multifunction DAQ
Obtain setpoint of analog out task
I have a function that sets an arbitrary voltage to an analog out channel (-10 to +10 V, NI 6211), using daqmx -> AO voltage -> Analog DBL 1Chan 1Samp.  I'm trying to find a way to later get that value back (which should be the value still applied at that channel). I could not find a way to read a property of the channel or the task to get the applied voltage at that port.
Using 2023Q1
(443 Views)
Accepted by topic author MF0088
It's possible to measure it using an internal AI channel with a syntax like "Dev1/_ao0_vs_aognd".   (Or you can do loopback wiring from AO to an external AI channel.)   That isn't always very convenient if you're already occupying the AI subsystem for other things though.
Do you need to physically measure and confirm it or is it good enough to structure your code to remember and report back the most recent successful AO update value?
-Kevin P
(419 Views)
