Multifunction DAQ
DAQmx execution speed
I'm programming a simple control application in C under Windows, with NI-DAQmx and Visual Studio. Using a USB-6003, the software reads a single value on each of 3 analog voltage inputs, does a bit of calculation and then writes a single value on each of 2 analog voltage outputs, the whole thing in an endless loop.
The excecution time for the calculation, loop overhead and everything else is just a few tens of microseconds. But the DAQmxReadAnalogF64 and DAQmxWriteAnalogF64 commands are taking around 1 millisecond each to execute - which is about 5x slower than I need it to be. I am using DAQmxStartTask before entering the loop.
Is this the best I can do with this hardware, or am I missing something? If the former is true, what direction should I go in to get these analog reads and writes running faster?
Thanks in advance!
(2,816 Views)
Accepted by DavidMoss
It seems that you are performing some sort of control, that should run live. Normally in this case, one needs a Chassis, like a cRIO or PXI, because they are equiped with controller hardware, on which the VI's run.
With a low cost USB device, calculation and VI execution will take place on your computer in Windows. This means that data is  acquired, sent over USB (which is not real-time capable) to the computer, perform calculations and then send some data back to the device for generating outputs. I have tried something similar with a USB-6211 and couldn't get the loop rate lower than 10ms I remember.
(2,788 Views)
Great, thanks, that helps a lot.
(2,781 Views)
