Multifunction DAQ
DAQmx error 200279
Hello, I have some problems using DAQms Read.vi, because after a time the program returns to mi error 200279, what can I do?
I have tried to change time out parameter, but i haven't result.
Thank you very much.
Luz
(3,162 Views)
The message that is returned with that error gives several good suggestions as to how to avoid that error.  I would try those suggestions:
"Increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples might correct the problem."
-Alan
(3,152 Views)
