Multifunction DAQ
performing DB DAQ there is a discontinuity between the two HB
 I am using a PCI_MIO_16E_4 card to Simultaneously AO AI a signal using  double buffering, CDA channel = for WFM and CAD channel 0 for DAQ.  The sequence of instructions used is as follows:
 Init_DA_Brds(); WFM_Scale(); Set_DAQ_Device_Info(); WFM_DB_Config ();  WFM_Group_Setup(); WFM_Load ();
 Select_Signal (); Select_Signal (); DAQ_DB_Config();  WFM_Group_Control(); DAQ_Start( );
 while(ulContCicloAOAI < ulLimiteMaxArEntEscr){       /* Do the double-buffering --------*/
     WFM_DB_HalfReady ();
    if (iReady == 1)   {
         WFM_DB_Transfer ();
         ulContCicloAOAI++;}
     DAQ_DB_HalfReady();
     if (iReady == 1) {
         DAQ_DB_Transfer(;}
     ProcessSystemEvents();
  /* Disable timeouts*/
 // Clear the analog input
 DAQ_Clear(iDevice);
 AO_VWrite(iDevice, iChan0, 0.0);
The problem is that in the junction of the two HB, there is a discontinuity caused by the 2nd HB starting from cero instead of from the point the 1st left the data. Can anybody help me? Thanks in advance.
(3,194 Views)
Eugenio,
Have you taken a look at the double buffer shipping examples?  You can find them in ..\Program Files\National Instruments\NI-DAQ\Examples\VisualC\Ao.  Also, is there a reason you are using tradition NI_DAQ functions.  I would highly recommend using NI_DAQmx.  Continuous generation examples can be found in ..\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog Out.  Take a look at these examples and see if they help you out.  Thanks and have a great weekend!
LA
(3,185 Views)
Hi Irallen:
Thanks for your reply.
The main reason for not trying NIDAQmx is that I have got Labwin CVI 5.01 so I will have to either migrate to version 7 or change to Labview. You have convinced that I must change my software and I will do it.
thanks again for your help.
eugenio.
(3,166 Views)
