Multifunction DAQ
DAQmx - counter input and output at the same time?
Hi Kevin
If I understand correctly. It means that one counter can generate one counter output and one digital output. With this coorelated DO, I can save one counter. Another counter can be used for the encoder reading. Do I have same frequency of PWM and different duty cycle of PWM? Thanks! Because I want to set different Duty Cycles of both PWMs depending on the demanding load voltage.
Message 11 of 13
(290 Views)
I didn't really look over all the code once I saw the attempt to do 3 counter tasks with 2 counters.
For independent PWM control, you'll need to 2 counter output tasks.  So then you'll need a 2nd USB-6259 to read your encoder.   Never mind about correlated DO, it isn't going to work out for your needs now that I understand them better.
-Kevin P
Message 12 of 13
(286 Views)
Thank you Kevin! I am using two USB6229. It works now.
Message 13 of 13
(277 Views)
