DAQmx Create Channel (AI-Current-Basic) 8 Channels with different Shunt Resistor Values
i want to measure 8 Current channels with Different Shunt Resistor Values.
Problem: The DAQmx Create Channel (AI-Current-Basic) specifies only one Shunt Resistor Value.
How can i set the Shunt Resistor Value for every Channel individually?
Regards
Marcel
(3,318 Views)
Accepted by Marcel_C
Hi Marcel_C,
take a look at me attachment.
Best regards
Dippi
(3,307 Views)
thanks a lot for your response. I found an alternative solution for this problem.
Take a look at the attachment to see how it works
BR Marcel
(3,305 Views)
